UnitQute internal temp question
Posted by: ChanYee on 21 May 2011
UQ has been in " mute" for over 8 hours.
During the winter it was hovering around 32-34C but lately it's been in the 44C range.
Can anyone help?
As the ambient temperature increases I would expect the temperature of the Qute to increase as well. Just checked mine and it is at 40C from 34C in the winter.
Neil
Tog
Cold corner of the house and I insist on everyone wearing an extra jumper rather than turning the heating up
. (The temp will drop significantly during the night when the heating is off - it is only on for about 5 hours a day in the winter).
Neil
17/18C.
Never even noticed that feature before. But just checked and its 30C, its been on mute unused all weekend.
I normally turn the VOL down & switch the input to CD which is un-hooked when i put the UQ to mute.
I have never seen it at 17/18C even during the winters. How is that possible.
40+C at idle really is quite hot and inefficient! Naim's comment on this is most welcome..
I was referring to the room temp. Temp of UQ has been down to the low 30s.
I believe that I read somewhere that it is best to select 'Analogue' when not in use as this turns off the digital circuitry. And mute obviously.
Neil
I'm almost always on analog, and mine idles at 45 or so.. When playing vinyl, it goes up to 50-55.
