Voltage Range
Posted by: Nori on 09 December 2015
Dear all,
My unitiqute2 which I was purchased was marked 230V at the back of the unit. I would like to know if the voltage input should be strictly at 230 voltage? If my area has a voltage higher than normal, say, as 242V , would it cause any damage to the unit? As heard from others, most gear would accept a +/- 10% variation! For the unit working in such prolong voltage, is that ok?
Thanks all!
