Problems with the Unitiqute 2 & app
Posted by: magicaxeman on 09 December 2015
Everything had been running tikity boo since getting the UQ2 and setting up my NAS drives & network but lately its been playing up.
The problem has been that over the last few weeks if I leave the UQ2 overnight the next day it won't play from the NAS, it just comes up as "searching" and then "track skipped".
I ran the suggested network checker on my iPad and the one thing that stood out was bonjuer isn't running on the UQ2 at all, is that significant?
The network seems to be working fine and I have no other issues apart from having to constantly power off and then power on again the UQ2, which is a pain for me as it means waiting until a carer gets here. ( I can't reach it and didn't want to use a remote power socket due to noise)
My system is based around an Asus RT-AC68U router so not a cheapo freebie router but a well regarded one.
3 x Buffalo link station NAS drives ( 2 x 2TB back up drives & a 6TB Main drive as iTunes/media server In another room) are connected to a Netgear switch, via cat 6 cable, the switch is then connected via cat 6 cable to the router in my main room, the UQ 2 connects to the same router via cat 6 cable and my macbook is also connected to the router the same way. No cable runs exceed 5 metres.
The app is running on an iPad mini 2 running iOS 9.2
Yes I store all my media in iTunes and my iTunes library is located on the 6TB NAS (Running as 2 x 3TB drives, mirrored) and have never had a problem doing so with either my old windows set up or the mac system I now use.
Any idea's at all? or does the UQ2 need a visit to my local dealer?
