stream to an airport express
Posted by: balma01 on 19 December 2015
I'm buying an AirPort Express to stream some xmas songs from an ipad to a naim uniti.In the apple faq I see that an airportexpress can join a third-party network in wireless client mode (802.11n) or connecting it via Ethernet (100mbs) to a LAN port on the non-Apple wireless access point. Which kind of connection to Choose? Wireless at 300mbps (theorically) or wired at 100mbps (theorically)  ?
Posted on: 19 December 2015 by Simon-in-Suffolk
connect the Ethernet patch lead from Express to a lan port on a switch or router for best throughput and performance
Posted on: 26 December 2015 by Hanover33
Agree - otherwise you may get drop outs depending on your wireless. Of course, if you'd rather not run wires, I find that wireless is fine most of the time from an iPad to an Airport Express then optical into my SuperUniti.
Also note that airport express will not stream above 16/44 so I only use it for convenience vs. quality for my tastes, however there is also a nice write up here:
http://www.kenrockwell.com/app...dio-quality-2014.htm
