Wave or Flac: Metadata questions
Posted by: Arnaud on 04 January 2016
I've been ripping quite a lot of CDs now with dBPoweramp, and I found that there were no differences between ripping to FLAC or to WAV in the metadata dBPoweramp found/extracted from the CDs:
- does it mean there are no more differences now between the two formats? Or does that only apply to CD rips, and not to downloaded files?
- or is this problem more critical with Classical Music (I mostly rip rock CDs)?
- and by the way, on new CDs, I often get poor results on metadata provided by dBPoweramp, be it FLAC or Wave (sometimes it doesn't recognize a CD, or it provides totally wrong metadata: i.e. a "Rush" album instead of the CD2 of the last Rolling Stones "From the Vaults: Live in Leeds 1982"), whereas ripping it into iTunes (Gracenote database) recognizes the CDs correctly: has anyone faced the same experience? Is it a dBPoweramp issue? Is there a way I could "force" dBPoweramp to go and search in the Gracenote base?
Thanks for your help!
Arnaud
