Line Conditioners or Not and Why
Posted by: Paristhea on 05 January 2016
As per my above subject, i am now considering a venture into either Isotek Serius or Isotek Gii Sigmas (used).
I was told that Naim and possibly few other high end manufacturers do not recommend the use of Line Conditioners, so i like to ask if this is the case and more importantly, why?
I currently have both the Serius and the Sigmas under test at home, and i must admit, the Gii Sigmas is rather impressive.
System: Linn Sondek LP12, Lingo, Ittok, Naim Nac-272, NAP-100, ProAc Studios. Project RS phono stage.
Posted on: 05 January 2016 by varyat
Perhaps you could try an experiment- take the "filter" out and plug directly into your mains. How does it sound?
ATB,
Mark
Posted on: 05 January 2016 by blythe
I tried a few, albeit a number of years ago and felt, without exception, that they sucked the life out of the music.
Posted on: 05 January 2016 by jon h
How about doing something radical like measuring the mains quality before and after? This isn't hard.
Posted on: 06 January 2016 by Paristhea
varyat posted:
ATB,
Mark
Well, i tried many different options, with mains only, with some items on the "filter" (like power amp only, power and pre amp only, etc), and generally with the Sigmas "filter" sounded better overall.  With the Serius it also sounded better, but the difference was not so significant.
I definitely left the LP12 on the mains, not through the "filter", because i already have the Lingo which i think acts as a filter anyway.
What did you mean with your above comment, trust my ears?
blythe posted:
I do not know, which is why i am asking the forum.  So far i think the results i am getting are not bad, but i like to have a technical explanation (if possible) why one should or should not use these devices.
jon honeyball posted:
I have not idea or instrumentation of how to do this.  If i could i would, for sure.
Richard Dane could perhaps give me some reply on the topic, if available.  I would really appreciate this.
Posted on: 06 January 2016 by Huge
Jon,  I know we're looking for a pure 50Hz sine wave (unachievable I know), but can you tell us all the waveform defects that affect our systems, so we can specifically look at the ones that matter to us?
Posted on: 06 January 2016 by Mike-B
Power conditions IME are a variable mix of how effective they are & there are also rumours around the hifi fraternity about spoiling the SQ which might well be true of a particular design,  but is probably not true of all.
Also keep in mind that what might be the case in UK with up to 250VAC,  might not be so in some parts of Europe that are running around 220VAC.
Most line conditioners include a number of components that reputedly spoil SQ - NB "Reputedly"
The inductors (chokes) used to filter common & differential mode noise will include an X & Y capacitor network,  it may be the case that the capacitors affect the sinusoidal wave form by shunting small amounts of energy between L&N&E & there is some softening of dynamics.
They also contain Varistor's (VDR or MOV) used for surge protection,  although normally set to operate above the nominal voltage - typically 275VAC,  they might trim the top end off a 250VAC wave peak.
Line conditions might be useful in locations that suffer with a poor power supply such as when heavily affected by local power factor loading, phase imbalance & high earth or neutral voltage.
Don't be confused with so called DC Off-set,  thats a separate issue & few line conditioners will fix this as they do not have the required special filter.
When I've tried the traditional line filters them they do nothing as my local supply is good - unlike my DC filter.   But if the line filters you are testing are doing something positive for you & your system,  why be concerned about why & how - go for it.
Posted on: 06 January 2016 by TOBYJUG
I don't think line conditioners all follow the same processes on what is done with electricity, I think there is a difference between a filter and a conditioner and also a regenerator. Best to find out what Isotek say about them - especially regarding the grounding.
Posted on: 06 January 2016 by jon h
Well for starters the distortion should be really low and should stay low under load. Testing for dynamic load is harder but not impossible
Posted on: 06 January 2016 by varyat
Paristhea posted:
varyat posted:
ATB,
Mark
Yes, trust your ears. If it sounds better to you with the line conditioner, then it is. Ime, the line conditioner acts as a "filter" and while it may improve certain aspects, overall it robs my system of the sparkle and timing that I enjoy from Naim. I am not familiar with the units that you have posted- perhaps they work better. A dirty mains is a difficult problem to live with . Fortunately, my dedicated lines seem pretty good in this regard. Good luck in your experiment!
ATB,
Mark
Posted on: 06 January 2016 by Super
I used a monster 8 bank mains cleaner on my AV2 set up which was on there other side of the room  from which my main hi fi was, because of the long line leads i was getting terrible buzzing and rf interference. I asked Naim if this would be okay to use because of what everyone said about main conditioners and they said " if you can get hold of one, try it." I did try it and it works and to this day it is still silent.
Posted on: 06 January 2016 by Mr Underhill
Paristhea,
Are you in the UK?
M
So do we just need to measure THD under load?
Just between Line and Neutral?
Posted on: 06 January 2016 by Olek_K
I'm using isol8 mini sub wave from UK. It gives much better resolution and I do not hear any problems with dynamics or "life being sucked". Before that I had another filter/power strip from Chang Lightspeed of USA. Less dynamic more polite sounding but also with some evident benefits - better soundstage being one.
Mr Underhill posted:
Paristhea,
Are you in the UK?
M
No i am in Cyprus
Huge posted:
How does one measure these things?
Paristhea posted:
Huge posted:
You use a spectrum analyser.
However it actually won't really tell you very much, apart form giving you a few numbers to write down, as you won't know how those figures relate to any possible effects on sound quality.
Posted on: 06 January 2016 by Singslinger
I found plugging in my Naims (Supernait 2 bi-amped with a NAP 250.2) to a PS Audio P5 power regenerator to have improved the sound significantly.
Posted on: 07 January 2016 by rjstaines
Paristhea posted:
Do you remember the days when we bought hi fi components by looking at their specs?  THD, RMS watts per channel etc etc. Never mind the sound, was it up to spec?
I'm going back to the seventies with KJ Leisuresound and Lasky's and similar retailers, so some forum members may never have participated in this specification war.
Then along came Naim... and the world changed !
Roger (feeling old)
Posted on: 07 January 2016 by Richard Dane
Paristhea posted:
I can't give you technical insight - I'd leave that to someone like Roy George or Steve Sells at Naim HQ (they will talk about impedance or some such thing) - but I can tell you of my subjective experiences.
The first was when we had a few mains conditioning units at the factory to try out.  All bar one were highly recommended by the various forums, magazines, the odd one out was a special lab unit that had come from the States and had been recommended by a few "in the know".  All made the music sound flat and uninteresting to my ears. One or two of them managed to do this by just being plugged in to the mains next to the system, rather than having the system itself plugged into the unit.
Next experience was at a dealer event in Sweden.  I had spent the late afternoon clearing the main dem room of extraneous kit, ensuring all bar the Naim system (CDX2, Supernait) was plugged in and setting up the Fraim stand and speakers.  Once all was just so, we sat down to try out some of the CDs and tracks that I always use and are now so familiar to me - this way it's easy to know when the system is doing things right or not.  It was good in many ways, but it was also just a bit "flat" and wasn't soaring the way I knew it should have done.  Around the room were curtains that hid flush shelving.  I had left some items on the shelves because there was nowhere else to put them.  Nothing else looked like it was  switched on.  However, I noticed what looked like a big silver fronted power amp and it had the logo of a well known brand of very expensive mains conditioners on its front.  I pulled it out from the shelf and lo and behold, it was still plugged in to a mains socket.  I unplugged it and put it back in place on the shelf. I drew the curtain and we all sat down again to listen...
Suddenly the system had life.  It soared.  It was quite a change - hard to pin down but undoubtedly the music seemed freer and less constrained, with better flow and much more "real".  It was so profound a change that we all just sat smiling, laughing, slightly stunned that it should have made such a difference to the system.
So, that has been my experience.
Posted on: 07 January 2016 by Ravenswood10
I use Isol-8  Powerline AXIS blocks in my system to remove the DC. Sound quality is much as before but without a host of Naim transformers buzzing away to the music. Usual issue of rubbish rural mains quality!
Posted on: 07 January 2016 by catalinmetal
and that is because we should look at our gear like being on a loop of electricity. this is why power cables make differences in sound. and the conditioner Richard tell about, while filtering massive on it's output side, was leaving it's own noises at the other "output" - the electrical network in that room.
it's mechanical/electrical "hum" was therefore added to that network when plugged in, regardless if it had something connected to be filtered or not. when removed from the socket, that extra hum had disappeared leaving the local electrical network a tad more "clean"... a good benefit for the CDX2/SN as Richard noted.
Posted on: 07 January 2016 by Huge
catalinmetal, I don't think that mains conditioners tend to add noise or hum, rather they load the mains supply in unexpected ways, particularly in terms of their impedance curves and tendency to self resonance (particularly on the primary side).  When this is then coupled to the complex impedance of a linear PSU (it being plugged into the same mains circuit), even more complex resonances arise.
These electrical effects can cause an increase in unwanted parasitic frequencies appearing on the mains sine wave.  It can also cause short term mains transients (which are often only a few microseconds duration) to induce ringing at these resonant frequencies, so causing more problems than before.
