Speaker cable lenght under 3.5 m
Posted by: 56wilson on 07 January 2016
I think I once read that it is okay to go under the recommend cable speaker lenght of 3,5 m on the integrated amps as 5i, XS and Supernait, but definitely not the poweramps.
Can anyone confirm that?
Posted on: 07 January 2016 by ianrobertm
Yes, I think I have seen that said. That the 'modern' stuff is less demanding than the older Classic amps. However.... please - get a definitive answer from Naim, before acting on this.
IanM
Posted on: 07 January 2016 by joerand
ianrobertm posted:
Great advice. Best to get the answer straight from the horse's mouth rather than rely on any old Joe on the forum.
support@naimaudio.com
Posted on: 08 January 2016 by The Man With Nonaim
For what it's worth, I once ran a 202/150 with 3m lengths of A5. Had no problems whatsoever. I have to agree with Ianrobertm. The cb / olive amps might not be so accommodating so worth checking with HQ.
Posted on: 08 January 2016 by ianrobertm
I can confirm that my CB/Olive 250 is fine with two 7 metre runs of NAC A4.
(Yes, thats right. Before A5... Berfore Naim put their Naim on it to...!!  7 metres was a guess - and so far has been fine for any system set up I have used, in several different houses. One more soon....)
IanM
Posted on: 08 January 2016 by Richard Dane
7m per channel of NACA is just about optimum I find.
There's no point going under 3.5m per channel.  Firstly, even if the newer integrated amps are more tolerant, you'll always wonder, what if?  Secondly, if you upgrade to a separate power amp, you'll need at least 3.5m per channel.  Thirdly, if you ever wish to sell your NACA cable on, there's not much market for lengths below 3.5m, for all the aforementioned reasons.
Posted on: 08 January 2016 by Mike-B
Its also worth remembering that the 3.5m recommendation is really addressing the required amp inductance loading:   The amps need a 3.5uH load & with NACA5 @ 1uH/m the math is easy.  The problem is the inductance spec of non Naim cables is rarely published,  so without this info with non Naim cables its best to go longer in any case.
Posted on: 08 January 2016 by Ryder35
Or just get SLcables; they come in 3m lengths
Posted on: 08 January 2016 by 56wilson
I like chord cables, so if I in the future goes higher up the naim ladder with pre and power amp, 3.5 m Chord speaker cable is not enough? If not, what chord cable lenght would you recommend?
...as minimum lenght?
56wilson posted:
It depends on the specific Chord cables inductance,  & they don't publish the info.
Based on the commonly used cable configuration & materials calculation estimates,  I expect the twisted paired cables like Odyssey to have less inductance than the separate & screened conductors like Signature.
However I use Chord Odyssey & I have measured its capacitance at 62pF/m,  that ties in more or less the same as the configuration theory predicts.  The theory says its inductance should be 0.6uH/m.
Therefore 3.5 / 0.6 = 5.83m to achieve 3.5uH per cable run
So 6m per side will be just fine.   I have 5m - & nothing is smoking yet
I just got replies from Chord cable doctor and naim.
I asked specific the cable doctor about the chord epic twin. He said I could go down to 3 x 3 m lenght. I asked about the nait xs in my mail, but as I understand his reply he meant naim in generally.
Naim's answer was that if a manufacturer advises that shorter lengths of their cables are okay then thats their recommendation based on their own specs on speaker cables.
Posted on: 08 January 2016 by Mattnbarns
I ran 2 3m lengths of TQB into a 140 for a couple of years with no issues.  I currently use the same cable with an SN2. Still no issues.
So bacically 2 x 3 m Chord Epic Twin equals 2 x 3,5 m Naca5 according to Chord.
Posted on: 08 January 2016 by Donkeyhaute
I'm using a pair of 3m Tellurium Q Black with a Chrome Bumper NAP 250 and it's absolutely fine; slightly above body temperature on the casing when playing at 40+ from a SU.
Posted on: 08 January 2016 by Finkfan
Mattnbarns posted:
Like Matt, i too use TQ black. Details on these cables are hard to find, but I did find on one site that the TQ Black is 1.2mH per m. So 3m would be 3.6mH which will be ok. No problems on my system. Can't find any info on cables further up the range, but will keep looking.
Well....just found a site that says the TQ black is 25nH per m. That's put a spanner in the works. Non the wiser
My Naim dealer also confirmed  that the TQB would be fine with a CB NAP.
56wilson posted:
I very much doubt it.  Epic Twin is a twisted pair & NACA5 is a spaced parallel pair - this spacing is a deliberate design feature to give a high inductance.
I would expect Epic Twin to be somewhere close to Odyssey as I mentioned in my previous post.
Now before we go off on one,  there is a lot of unnecessary stuff around speaker cables,  with Naim amps I would always have it as long as possible & if its not NACA5 I would go longer  &  avoid woven/plaited types.
Posted on: 09 January 2016 by Finkfan
I guess the super lumina cables are slightly more inductive then, as they start at 3m lengths.
Posted on: 10 January 2016 by joerand
Maybe prohibitively more expensive fed into that determination?
Posted on: 10 January 2016 by Mike-B
Finkfan posted:
I have yet to see any data published on the SL's.  However as they are separate & screened conductors,  then they will have a higher inductance than does a twin pair cable.   Is it the same/similar inductance as is the managed spacing of NACA5 ???  lets wait for Naim to tell us, if they ever do.
Posted on: 10 January 2016 by sheffieldgraham
Mike-B posted:
Finkfan posted:
Doesn't really answer the question ,but Steve Hopkins told me a 3m SL run would be O.K. with my NAP300.
p.s. Presumably this makes it O.K. for the other Classic amps
Posted on: 10 January 2016 by Claus-Thoegersen
I run 2.5 meter Chord Signature that is 6 pairs, with a 200 and 2 250s, clearly not in line with the advice from Naim, but fortunately it has not given me any problems in the more than 7 years I have used the cables.
