A Question about DBL's
Posted by: Mario on 08 January 2016
Hello all, I have owned a pair of cherry DBL's for about 5 months or so and have been quite happy with them. I previously had NBL's and they are definitely a big step up. The thing is, that the best part of them for me is their mid range and treble purity, naturalness and true to life sound. When you look at DBL's, the first thing that you would expect to be raving about is the bass response. Bass is good, but I just feel there is much more to come. I have just recently purchased new DBL spikes (old ones were a little blunt) and used fraim chips (upside down) and levelled the speakers too perfection.
The thing I have never done is the gasket. Now my DBL's have been well looked after and the gasket seems to be very done, but both speakers have been transported more than once with the bass box still in place. The seal still seems perfect, looked with a torch and they both look in tact. I'm not willing to push the driver in to check the seal as it seems very stiff and rigid. I have no problems pushing in the SBL mid/bass as it is much smaller but don't really want to put much force on the big 15 inch driver. Any way, my main question is about the aluminium pads.
The DBL manual instructs to push the bass box down gently on a dry run to create an IMPRESSION on the aluminium pads. I am guessing that my spikes have probably punctured through the pads, but if you read the SBL manual, it actually says to push the bass cabinet gently until you actually puncture through the pads and allow the spikes to come into contact with the wood. I just can't see if my pads have been punctured, the gap and angle of sight is just not good enough. Also, the DBL manual does not mention the soap on the gasket for easy removal, and I don't think mine have had soap on them as they don't seemed to have moved during transit.
My question is simply are the spikes on the main cabinet supposed to punch through the aluminium pads on the DBL's bass box, or is only an impression supposed to be made?
I have read people refer to the aluminium pads being changed because they are perforated, so I guess that means only an impression on the pads must be present, but not sure.
I actually have new gaskets but I don't think soap or dish washing liquid has been used on my gaskets prior to the silicone being applied so it will be a bit of work. It's really the SBL manual that has placed doubt in my head as it says to push the spike through the pad. Don't really want to destroy the gasket if the spike through the pad is ok.
Floors are suspended wood type and rear wall is only a stud and plasterboard wall, although, this did not seem to bother NBL's too much when they were in the same space!
Best regards
Mario.
p.s. Jon Honeyball, Ron Toolsie, Peter Swain, Officer DBL and all other resident DBL experts, I'm hoping you can help with this one! Thanks.
t
