NAC 282 Record Bank auto switching to match Source
Posted by: Nigel on 09 January 2016
Hi
Does anyone know if it's possible to configure a NAC282 so that the selected record bank automatically switches to whatever is select on the source bank?  The reason for this is that the 282 is not located in the listening room and sometimes I use headphones.  Therefore, if I don't select the source which matches the record bank then the headphones don't get a signal; in which case I then need to wander into a different room to select it.  It's just an irritation and not a major issue, but if this could be sorted it would be great.
Many thanks for your help in advance.
Nigel
Posted on: 09 January 2016 by feeling_zen
Not simultaneously no. No way to do this from the Naim app either but the standard remote supplied with the 282 has a "rec" button for controlling the record out. If you have an IR relay device setup in the two rooms you can use that.
Posted on: 10 January 2016 by Nigel
Ahh good point; before I started using the Naim app did have a IR relay device.  I shall dig this out.
Many thanks for your help.
Nigel
