Unitiqute 2 + Linn Tukans
Posted by: docbot on 09 January 2016
I need to organise a demo but I am starting to think about possibilities. I currently have a Linn Genki, Kolektor, LK140, Tukan passive system. I am planning to replace the electronics with the Unitiqute. It would be good to keep the Tukans whilst I investigate replacements. Does anyone run with Tukans. Does the Naim run happily with them?  Thanks for your thoughts.  Mark
Posted on: 11 January 2016 by docbot
No one using Tukans? I am somewhat surprised as these are lovely little speakers :-)
Posted on: 12 January 2016 by David Hendon
If you search on the word Tukan within the forum, you can see every post that has mentioned them in the time the Naim forum has been going. There are quite a few posts!
best
Posted on: 12 January 2016 by docbot
Thanks David, yes lots on Tukans but nothing I have found of their use with the Unitiqute. Can you point me in the right direction?  Thanks
I don't know the Tucans myself at all, but from a quick look at the spec on the Linn website, they seem like they shouldn't cause any problems with the Unitiqute 2 which is quite flexible in its loudspeaker partners. So I would have thought you could get your UQ 2 and safely use them while you considered whether to upgrade the speakers and if so to what.
best
