Dear venerable lads and lasses
Like for many others during the new year, some new upgrade ideas came up and the NDS + 500 classics are highly revered as a source + amp set up. Following a retailer demonstration based on this and including some large Naim speakers (big Ovators) it was a real revelation to hear this high end level of performance. The shop had a repertoire of music covering classical and jazz music, which the NDS + 500 delivered with immense scale and precision. It sounded clean and full bodied compared to what I'm accustomed to. Classical and jazz aren't genres I'm in to so I'd only imagine that the realism it conveyed is like going in to a concerto hall or jazz café. Other music comes out well, esoteric and sublime listening such as on Radio Paradise. Or for the heritage acts.. Beatles, Pink Floyd, E.L.O, Wham! George Michael etc...
The problems arose when selecting other genres. Upon 26-27 minutes of listening to youth-oriented modern rock and its sub-genres, or electronic/ dance and its sub-genres the NDS appeared to stumble and lag behind the setups closer to the entry-level. NDS + 500 can come up with some pace, but ultimately feels slower and the structure of the music itself felt like it was being segmented and staggered, like it was struggling to hammer out the music. The overall musical delivery was being subdued and suppressed when hearing youth-driven, highly energised and explosive music. Please forgive for this metaphor; it wasn't entirely "pedestrian", more like "senior citizen running to get the bus before the doors close". Unfortunately an unfulfilled experience with the upper end of the Naim selection. It gave the impression that there are two forms of Naim sound.
1) Mature Naim - around the reference end, NDS and 500: Lots of grandeur and prowess for sophisticated listening, large scale refinement and great for sublime and esoteric music. Nice realism and low noise factors for classical and jazz.
2) Young Naim - around the entry level: Boppy and nimble. When set up in the desired way, will deliver music which sings its heart out, goes very fast, aggressive rowdy and more dynamic when needed. More meaningful for young music.
Furthermore I've found recently that by not using any kind of DAC (either Chord or Naim) and sending signal from a 'lesser' source straight to Nait XS-2, will allow the music to really sing its heart out and keep a better linear momentum and rapid fire shifts in dynamics. This will happen for numerous examples, where the music is forward and shouty. Could be psychobilly, mod rock or shouting British punks through to newer American hardcore punk.
This is a bit audio-philistine, by simply using a Sony mp3 player, iPhone or Mac wired straight in via a 3.5mm stereo to DIN cable (worth £1.45) the music can often come across better than by using a CD player -> Naim DAC -> Nait XS-2. It will revert back to being more of a "stereo system" sound, along with any of the electrical or RFI noise that these sources emit. Nevertheless the music itself comes across with a certain rightness, attitude and meaning. Other more challenging music (death/ doom/ thrash/ cyber/ industrial metal, metalcore and modern rock) and dance/rave/ trance/ club etc... generally come across better with a source straight to Nait XS-2, compared to when there is a high fidelity DAC sandwiched in the middle.
Neat Motive 2 speakers are currently being used and this seems to provide an ideal arrangement, based on standing listening only - no seating or chair position. It is for linear trajectory of sound from the speakers and being about 1 metre distance from either left/right speaker. Also I'm thinking that metallic tweeter drivers provide the best performance for rapid fire reaction for dynamic changes in the sound & linear high velocity music.
If you can identify with any of the descriptions above, does anybody have experience in creating a Naim set up that is exclusively leaning towards a youth-driven character and sound? One which will excel at all levels of modern rock and electronic/ dance? How far up the upgrade chain did you go, or indeed if you were to retrograde back down to the Naim entry level heroes? Do the Cyrus audio amplifiers provide more drive and aggression than Naim amplifiers?
Posted on: 10 January 2016 by Jan-Erik Nordoen
Interesting observations. I think there is some correlation between the level of Naim system and age of the listener. There is also the effect of "time expanding" as you move up the preamp range (and add the SL cables...), which will be heard as a "slower" presentation to some.
When we're younger, we're more physical and react to music in an external, physical way. Older, we listen more "internally". I may be 60, but I can still dance... in my head.
As to your question, the 272-250 duo definitely appealed to my 29-year old son and his friends, as does the mu-so.
Perhaps you"re too young to appreciate the NDS
Posted on: 10 January 2016 by Huge
Disposable, how much of the perceived difference is due to the speakers? Neat Motive 2's are a far cry from Ovator 800s. A Nait 5i or XS-2 will desperately struggle to drive Ovator 800s, so you would need to use the Neats for both systems to get a valid comparison.
As for music sounding better using a portable device's internal DAC and a 3.5mm jack to DIN cable vs, a CD player or better DAC, I couldn't disagree more strongly. I use a laptop with a cheap USB->S/Pdif converter into a ND5 XS to drive a Nait XS-2, and the result is way better than any of the portable devices or laptops I've used via the 3.5mm jack connection from their headphone output. This is so both with and without RFI protection on the analogue cable.
My experience with Cyrus CD & amps is that, in comparison to the Naim kit, the sound was somehow slightly disjointed or less coherent. Not bad, just a little less convincing, however in comparison to the 5 series components, there was sometimes a little more detail. After a direct comparison, I'd still take the 5 series components every time (and we did!).
Posted on: 11 January 2016 by Innocent Bystander
I always thought the age aspect was more to do with cost, whether to do with disposable income (families grown up etc) or because the higher echelons of Naim gear tends to be the pinnacle of many people's HiFi journeys, taking years of upgrading investment to get there.
Relevant in the OP description might be that many people on this forum seem to be predisposed towards jazz, second maybe classical. Personally whilst I love classical, I (don't hit me for saying it!) can't stand jazz, instead mainly into heavy & prog Rock, and tragic opera, so maybe that's why I'm less taken by the focus on PRaT and far more on the realism of the sound, which benefits from accuracy...
As for the original question, given the apparent preference for MP3, I wonder how much it may be a matter of conditioning: To some listeners, possibly a preponderance of younger people primarily into modern street/pop music, and possibly not being familiar with live music (discounting sampling DJs from the definition of live music), the sound of MP3 they have grown up with may simply be what sounds right through familiarity, and opening up the sound makes it sound wrong...
Posted on: 11 January 2016 by Iconoclast
I think that as we get older (more mature if you prefer) our tolerance for twitchy, snappy, zingy or PRaTty diminishes in favor of more a natural relaxed presentation.
Same goes for music. I don't listen to the Pogues or free jazz much anymore - they tend to get on my nerves really fast.
I now prefer a mix of well recorded electronica, good pop/rock/alternative/indie, opera, classical as well as smoother (NOT smooth) jazz and blues. No Kenny G. please and I still find a lot of those linear ECM and audiophile recordings rather depressing.
Result: the Nait 5i was traded in for an XS 2. While at times I do miss the little bugger's spirited character I doubt I'd be able to live with it long term again.
In other words I'm not ready for the Shady Acres retirement home but instead of flying down a bumpy trail on a mountain bike I now prefer a good cardio ride on a paved bicycle path by the river.
That doesn't apply to us all - other than the discovery of tragic opera my taste in music hasn't changed for over 40 years, and I have always sought accuracy/realism out of music systems, and have never understood PRaT (maybe something to do with not liking jazz and never having been into dancing in any way...).
But then I still like to play my music at realistic levels, ride my bike as fast as my not so young legs will let me (which isn't as fast as it once was, and I've never been in the slightest bit athletic), and ski, climb etc, meanwhile hating the fact that stamina isn't what it once was, and having to accept the wisdom of taking those blood pressure pills and having to use a magnifying glass or reading glasses to see fine detail...
A few years ago there was the wonderful news promulgated by medics (that well-known body of tea-totallers...) to the effect that a glass of wine a day was good for you, and I'm sure others, like me, took that up with glee, freed from any guilt ...while glasses ever increased in size.
now there's spoilsport guidance from UK health saying we should limit to 2 smallish glasses a day, and miss out 2 days a week. If I follow their advice yet suffer a heart attack I'll know who to blame!
seriously though, it all depends on what might be causing something like high blood pressure, and trying to find an appropriate way to keep it down. For me it's only marginal, and I have scope to try various diet or lifestyle options to see if I can negate the need for medicinal intervention. But increasing butter intake isn't one I'd thought of! - might make the blood slip round corners easier, so reducing the force needed, and thus lower blood pressure.......
Sorry, a bit off topic, if irresistible.
Posted on: 11 January 2016 by CharlieP
Innocent Bystander posted:
"... I wonder how much it may be a matter of conditioning: To some listeners, possibly a preponderance of younger people primarily into modern street/pop music, and possibly not being familiar with live music (discounting sampling DJs from the definition of live music), the sound of MP3 they have grown up with may simply be what sounds right through familiarity, and opening up the sound makes it sound wrong... "
I agree that we form opinions about how certain recordings "should" sound.
Many think there is no bass if the "Loudness" button is not on. I have a friend who always turns the volume up too high (the distortion drives me nuts!) - I have concluded that it is the distortion that defines "loud" for him and he perceives it as more exciting. Distortion is in fact an almost defining feature of some genre's of music. While distortion is inherent in some recordings, some is introduced by the replay chain. If one is "familiar" with a certain recording with a level of replay distortion, then one hears the replay with the added distortion missing - one can feel it sounds too "polite."
Disposable Hero,
Give a few examples of the music tracks which sound "better" as "young Naim."
Charlie
