Aerial Cable and Connectors for NAT-01 and Galaxie 17
Posted by: Jack911 on 17 January 2016
I'm finally getting around to setting up my NAT-01.
I have a circa-2010 Galaxie 17 and I need to decide what cable and connectors to use.
I expect that WF100 will be suitable, but which brand and type of connectors should I use?
Posted on: 17 January 2016 by Mike-B
WF100 is Webro
I have "F" type connectors at my wall outlet - these are the so called "satellite" screw thread type - see the picture -  & a better connection in all respects, maintaining 75ohm, more secure & easier to install than those 'orrible Belling-Lee plug in things.  I have not found a better/worse F connector make,  but I would go for a good quality wall socket such as MK.  Also be aware that if you have an existing wall socket position that you intend to use, the metal back box might not be deep enough to take the more bulky RF screening cover of the new socket.
The NAT will need a female to male Belling-Lee,    but instead of a straight one,  think about a 90 degree angle as a possible better way to dress the cable to the NAT
Posted on: 17 January 2016 by Jack911
So is WF100 the best cable to use?
Its my preferred cable:  I like the foam insulation over the air spaced cables. It bends easier, is less likely to deform & the centre core is less liable to break through a tight bend over time - but whatever don't over bend any coax cable.  It does not take on water as can the air spaced.  Finally,  its performance is as good as any.
Posted on: 17 January 2016 by ken c
i was also recommended (by Ron Smiths) WF100 cable and i have it lying there -- but i cannot find someone to install it where i live in Herts.
enjoy
ken
Posted on: 18 January 2016 by Jack911
Does anyone know which connector can be used in the NAT-01?
Is F-type OK or does it need to be Belling-Lee?
