Signal ground
Posted by: Hal on 17 January 2016
I have UQ2-Nap100 combo. It is only hardwired to Linksys switch. Nothing else is attached. Signal ground switch is at chassis now.
I decided to give some oomph to the sound of my new TV. I'll run a toslink optical i/c to UQ2. I know that there will not be physical alteration grounding wise. But still I wanted to ask whether chassis or floating is appropriate.
Thanks.
Posted on: 17 January 2016 by james n
You've answered your own question Hal - no physical grounding changes so no need to move from chassis ground
Posted on: 17 January 2016 by Hal
Thanks for the quick reply, appreciated.
