15amp Plugs & Sockets vs 13amp Power Lines
Posted by: Rustyneedle on 17 January 2016
Hi, Simon's- in - Suffolk's topic 'Radial Mains' has raised the question that I have been
desperately trying to ignore for sometime.
Not wanting to hijack Simon's topic I'm starting anew.
Here goes....
Some years ago I had a separate consumer unit installed,3 x 10mm radial cables terminating into 3 x 15amp MK sockets and plugs
After years of upgrades I now have an LP12,552/500,nDac/555 into Titans.
This year we plan to have alterations to our house which includes electrical work
and I have Power Lines that came with the 500s never used.
The question that I have been avoiding....
Is it time to ditch the 15amp plugs and sockets and install the Power Lines?
Any help gratefully received,thanks.
Posted on: 18 January 2016 by FangfossFlyer
Is it possible and compliant to regulations to replace 15 amp sockets with those used in the USA or Europe and hence use a USA or European Powerline that does not require a 13 amp fuse I wonder?
Richard
Posted on: 18 January 2016 by Richard Dane
Richard, in the UK, I believe not.  Either way, even if you could the circuit would need to be limited in amps.
Posted on: 18 January 2016 by Steve J
In the UK we use 13 amp three square pin sockets. It is possible to use the euro plug in the UK (UK and most of Europe use 220-240V) and meet the UK regs although the polarity of the pins has to be marked as some UK electrical equipment has single pole protection whereas European equipment has dual pole protection. This obviously must be installed and certified by a UK electrician.
Posted on: 18 January 2016 by Dave J
An inherent part of the Powerline’s design is the plug itself so, although you could have them re-terminated with 15amp plugs, you’d negate some of the performance.  Having said that, I also have 15 amp sockets (plus a couple of 13 amps as much to make a comparison as anything else) on my dedicated mains, and whilst I used to use Powerlines and really liked them, I did sample a Chord Sarum mains lead which had been fitted with a 15 amp plug at the factory.  The result was that I ultimately invested in a complete set of Sarum mains leads, now all upgraded to Super ARAY.
At the level you’re at, kit-wise, you might find it worthwhile to try one or two.
Posted on: 18 January 2016 by Rustyneedle
DaveJ
Yes,I'd pondered over both those options.
Reterminate Powerlines with 15amp plugs,or have a mixture of 13 & 15amp sockets.
The 15amp plug to me seems to make sense,no fuse and bigger contact surface.
I may well have to initially have both so that I can make that comparison.
