New version of Naim app on IPad
Posted by: phosphocreatine on 19 January 2016
just downloaded the new release of the Naim app on my IPad Air II: it's now lightning fast in searching through the NAS with both Minimserver and AssetUPNP.
Anyone else noticed improvements ?
Updated app, unable to use TIdal on my ND5XS network player. Tidal app 'ready' shows in display. When searching or try playing stored 'favourite' music, app (on both I pad and I phone) hangs.
Tried the usual switch off / on, delete / reinstall app - no joy!
Normal Tidal app on I pad working ok. Any suggestions would be grateful..........
I have an NDX and Tidal and Spotify are working as usual (after the installation of the new Naim app).
Sorry for you inconvenience
Haven't yet done the upgrade - but it would be a great thing if search would improve.
Does anyone know if Playlist was fixed ![]()
Confirmed search is much faster, good work.
Just updated the app and I like the new feature to re-order tracks on playlists. It seems to function OK with me.
Sorry Idris, don't know what to suggest other than an e-mail to Naim
The updated app is working well here, using MinimServer and Tidal. The play queue reordering is very handy.
What about the android app? Any updates coming?
Idris Roberts posted:Updated app, unable to use TIdal on my ND5XS network player. Tidal app 'ready' shows in display. When searching or try playing stored 'favourite' music, app (on both I pad and I phone) hangs.
Might be worth checking you are logged in to Tidal on the Naim app. You can check this in Settings > Input Settings > Tidal.
Bug in multiroom mode.
On switching off music to the 'slave' upstairs from the app, the app cannot find the master device downstairs 'device not found' constantly reappearing. Hit 'ok' and a page appears showing the inputs for the device downstairs (the one I was originally playing music from before deciding to go multiroom and send a stream upstairs) but not the name of the device. Multiroom was always a bit of a flaky experience but this is a step backward.
Killing the app / rebooting app was the only way to restore the 'name' of the controlling device to the display, in my case 'Living Room' (if the inputs were identical on all uniti devices I would not have a clue which device was connected to the app at that time).
The font size on the iPad Pro has shrunk in the wash. The letters for the Artist/Track are now 2mm in height with capital letters being 3mm. That's fairly ridiculous on a tablet that's main claim to fame is it's large screen size. I'd like an option to increase the Artist/Track font size.
I wonder about this topic:
"Play queue reordering (long press track to reorder)"
If I am not wrong I already was able to do this in the last version of the iOS app? Or do I mix it up with the android app? Hmm, I do not think so.
gert posted:I wonder about this topic:
It was possible to do this on the previous version of the iOS app but it was very difficult to get the tracks to slot in where you you wanted them to go in the list order. They would either go in the wrong order or snap back to their previous position.
hafler3o posted:Bug in multiroom mode.
Well? Any response? I cannot change control of Naim devices via the app as the room name refuses to appear without killing the app and starting over. This is happening without multiroom mode too, I switched multiroom off and as soon as the iPad 'sleeps' on returning the last used room name above the inputs will not appear, meaning the device cannot be deselected in favour of another.
So if this is the wrong place to post bugs where is the right place as there was no response yesterday.
Any word or response to my point about the miniscule font size on the iPad Pro? Any reasoning why it has to be that size?
