Automation issue on the NDX with NAC202
Posted by: marcobb on 25 May 2011
Is it work on below combination?
NDX with NAC202
marcobb
Posted on: 25 May 2011 by Aleg
You'll find your answer here in a reply from Phil Harris
Posted on: 25 May 2011 by DavidDever
Yes, it works-what issue?
Posted on: 25 May 2011 by marcobb
Thanks every bros !!!
Should it use 3.5mm jack to one RCA ??? (NDX to 202)
You'll find the answer in the NDX manual section "2.9 System Automation" page 4
i think it should use 3.5mm to RCA for NDX to 202 pre-amp ![]()
Thanks a lot.
Posted on: 30 May 2011 by marcobb
It work right now, can throught the ipad control the volume ^.^
