Streaming from iTunes on uniti
Posted by: RM on 27 May 2011
Does anyone know how I can stream music from iTunes through naimuniti? Thanks
Rohit
Rohit
Posted on: 27 May 2011 by Tog
Well EyeConnect is probably your best bet for very basic UPnP streaming.
Tog
Posted on: 27 May 2011 by Oscar_F
I am using Jamcast and works fine also
Posted on: 27 May 2011 by garyi
In its simplest guise an optical cable will do you.
If one is being pedantic, optical out is not streaming
Tog
Posted on: 28 May 2011 by Simon Everest
Until Naim add AirPlay support to the Uniti, you can't stream directly from iTunes.
You can connect an Airport or AppleTV and stream to *them* from iTunes.
Unless I'm missing something, the suggestions above relating to UPnP don't have anything to with iTunes, which is what the OP asked about. Happy to be corrected.
Simon
Simon
Posted on: 28 May 2011 by realhifi
Rohit
Rohit
Depends if you simply want the music that is in your iTunes or you actually want to use the interface of iTunes. If you want to use the interface then no, you can't control iTunes streaming into Uniti.
If, on the other hand, you simply want to hear what is in your iTunes collection then you need to download a UPNP player (either Asset for a PC or Eyeconnect for the Mac) in order for it to stream to the Uniti.
