Qute/Speaker Cable Options
Posted by: bigsplice on 30 May 2011
Anyone experimented with different cable options with the qute? Using Naca 5 currently.
Posted on: 30 May 2011 by marcobb
No need think other......use the Naca 5 is the best
Posted on: 30 May 2011 by realhifi
Doesn't hurt to listen to a few.  All the ones I have tried have been pricier and didn't necessarily sound better, just different.
Posted on: 30 May 2011 by Steven Shaw
I tried some Audioquest type 4 when I got my unitiqute since I had some lying around. I've since changed to Nac a5. If I'm being honest I've not noticed much difference. Perhaps the audioquest was a bit brighter, and the Nac a5 having better bass, although using Naim Ibl's the bass isn't exactly very deep.
