Assign different buttons on the amplifier
Posted by: Bruno73 on 27 January 2016
I have a ND5XS and a NAIT XS2, and I would like to assign for iradio, upnp different buttons on the amplifier.
For example:
iradio will be on tuner button
Upnp on hdd button
Do you know how I can manage to do that?
Posted on: 27 January 2016 by Mike-B
No,  that is not possible.
The various inputs are a function of the ND,  but as it has only one output it can only go to one amp input.
In my case its UPnP (NAS),  iRadio, USB, TV & Tidal is all on the "CD" button (SN-1)
However I do have a separate NAT (FM Tuner) that is separately connected from NAT to SN,  I have programmed the app - via the NDX input "Pre-Tuner" - to switch the amp input to "Tuner" button
