CDS3 Transport Problem?
Posted by: PaulC on 27 January 2016
My Cds3 (2009 vintage with newer transport) has just started to misbehave. Tonight it Has been sounding as if the motor is spinning for no apparent reason when no disc was loaded, this is accompanied by the laser being lit. When a cd is loaded it seems to have trouble loading the TOC and then it will stutter during playback. No error code is shown (I do run it with the display off - if that makes any difference to error codes showing). I have just noted this behaviour tonight although my wife says she has heard the mechanism spinning before when no disc was loaded. The puck is the later magnetic one and not the earlier one with the rubber feet so I do not think that is the culprit though I will try a different puck tomorrow - for the moment it is powered off.
i fear this may mean the transport is failing although wonder if it may be a software issue.
Any thoughts?
Paul
