Nait 5 pre will not power up after un-plugging FlatCap2??
Posted by: Matty74 on 29 January 2016
Hi Folks,
It would be great if someone could help me or has come accross this before.
I was running my nait 5 in standard mode and then tried it with a with a flatcap2, listen to a few tracks and then I removed the flat cap and put the plugs back in the back of the nait5.
The 2 plugs with the ribbon connecting input 4pin and signal B 4pin and the single plug into signal A 5pin, but the pre will not power, no lights.
I plugged the flat cap back in and it powers up OK, and the amp will now only power up now via signal A 5pin.
So I'm completely stumped as to why the amp will not run the plugs and connections are absolutley fine.
If someone can help it would be greatly apprciated.
Posted on: 29 January 2016 by james n
You've got the connections right so i'd suspect either the link plug in signal A has an issue or more likely the flexy link between input and signal B has broken. The flexy link carries 24v (as well as the L&R signals and ground) from the input socket to the signal B socket. The Signal A link plug just joins the two internal 24v rails which would be split when using an external PSU. Have you got a multimeter to check continuity across the link plugs ?
Posted on: 29 January 2016 by Richard Dane
The ribbon link is quite fragile.  As James says above, it may be broken.  Check it out. You can substitute a SNAIC4 and see if that works.
Posted on: 29 January 2016 by Matty74
Its the ribbon just nplugged in a 4 - 4 snaic and it starts up fine, is there a replacement part for the ribbon plugs?
Posted on: 29 January 2016 by joerand
Matty74,
Welcome to the forum. Nice avatar. Did you add the nose & mouth?
no thats a real pic from a Sydney Bus
Good you've found the fault
LINK PLUG, FLEXI, 4-WAY, NAIT-5 is what you need - your dealer should be able to sort it out for you (or just keep the Snaic 4 in place)
James
Posted on: 29 January 2016 by Massimo Bertola
Matty,
I vote yours as avatar of 2016. Glad you sorted the issue.
Max
