Pre Amp with Phono Stage
Posted by: Bob Walker on 03 February 2016
Present system
lp12 armaggedon Ittock3 Ortophone Cadenza red
CDX2 XPS 2
102 K Boards Hicap 140
SBl's
I had my lp12 rebuilt by inspire , Upgraded CDX to CdX2
Would like to upgrade amps but not sure about separate phono stages
Bob
Didn't want to increase my box count
Bob, you don't mention a budget. Ideally then, if the budget is considerable and you don't want to increase the box count, how about a NAC552 and a s/h Prefix?
Otherwise, more reasonably, you could consider the Prefix with any number of other pre-amp options, or maybe even a Supernait 2. But as ever, it all depends on the budget - i.e. what you'd like spend and your absolute spending limit...
Thanks Richard The Prefix is an option
I was thinking maybe 202 , Hicap , 250 DR , with a seperate phono stage maybe but would have liked it in the pre amp
IME, the phono boards in CB and Olive generation preamps are fine if you are using a MM cartridge. After stepping up to a MC , the S,K boards can be easily bettered by a separate phono preamp
I've never heard a Prefix, but it has a good reputation when powered by a separate PS ( or the 552 as Richard has noted
, but this will bring another box into your rack.
I think you will find that getting the best from your TT will require adding another box- good luck!
ATB,
Mark
Nac202 with NAP250 is the ring way around - always ensure the preamp is a match or better than the power amp as its the more critical part of the pair.
How about a NAC282 with NAP200? Prefix can be powered from the preamp or from a Hicap. Or, of vinyl is the main source, a hicap or even a Superline with a Supercap. Now we're really talking. Spend what's left on the amp, even if it can only stretch to a NAIT.
Sorry, I meant wrong not ring. iPhone autocorrect...
thanks for the advice
... or buy a serviced 52 with the phono boards that you would like for your cartridge.
It is quite a good pre-amp and will go with anything from a NAP140 to even a NAP500, as it did in the early days of the NAP500.
Best regards, FT
Ah yes, good call from FT. A nice serviced NAC52 and Supercap. It can also power a prefix,and that would be my choice over the internal cards.
