Hi, I have recently purchased a Naim CD 5i player. Unfortunately it did not come with any transport screws / bolts. My question is, are they specially manufactured for Naim or are they a standard bolt that I can buy from my local hardware shop. If so does anyone know dimension/specification of the screw / bolt.
many thanks in anticipation
Joe
Posted on: 04 February 2016 by Joe-S
Richard, many thanks for the information and prompt reply. I presume that they can be ordered direct from Naim, so i will contact them later today
Joe
Posted on: 04 February 2016 by SamC
I'm not sure whether this is within rules to note - but when I had to ship my CD5i for repair, a normal bolt (the correct size, obviously) - worked fine. The official ones are no doubt better/safer of course.
Thanks Sam, I have just ordered 2 transport screws from tomtomaudioshop, they are only £1-78 each so won't break the bank and probably best to have the real thing.
