Superuniti preamp out not working
Posted by: analogmusic on 15 February 2016
Hello all
This weekend we tried Superuniti preamp out into NAP 200, but no sound came
Is there a setting to activate this preamp out?
Which cable is needed (we used the same Snaic that runs from NAC 202 to NAP 200)
Posted on: 15 February 2016 by ChrisSU
There is a setting to switch from internal to external amp accessed through the remote/front panel menu. You need to turn it to external, or you will get silence.
Posted on: 15 February 2016 by joerand
I always email Naim support before making a "first-time" connection in my system. Responses have always been fast and most importantly, correct. The folks there seem to know what they're doing
Posted on: 15 February 2016 by Richard Dane
As Chris says above, you need to select External Amp in the setup menu.
