CD5 Cable Connection Direction
Posted by: staffy on 16 February 2016
Disconnected the CD5  player 5pin din to 5 pin din cable.  It is marked to ensure the direction of flow.  Now the following day I have forgotten which way it should be connected.
Is the marker to be facing the CD player or facing the amp.
Yes, I know I'm sad.
Posted on: 16 February 2016 by Tony2011
CD player, Staffy.
Posted on: 16 February 2016 by staffy
Thanks Tony
Posted on: 16 February 2016 by Richard Dane
Staffy, the banded end always goes nearest to the source of the music signal. Think of it in this way and you'll always get it right.
Posted on: 16 February 2016 by nimrodmr2p
Why don't Naim implement a very simple measure
Put a piece of tape on each lead with a arrow indicating the direction of signal flow
Perhaps I could get a job in their design department, my priority tasks would be
No switch on thump for all amplifiers
CD drawers that stay where you position them
All paintwork having the same shade of black
Posted on: 16 February 2016 by hungryhalibut
So what would you do about a Snaic 5 when powering a CD5?
I think I would limit my brief to only the important issues
