Streaming rates on Superuniti
Posted by: Steve Smith on 17 February 2016
I stream FLAC files which I saved with powerampDB (I think that's the name) on to my Buffalo Linkstation. When I play through the Superuniti they sometimes play at different rates, including 128 MP4. I am sure I did not save them at that rate. The system is all wired up through my Talktalk router. Any ideas what might be going on?
Posted on: 17 February 2016 by J Saville
Your UPnP server is likely transcoding to MP4. You should be able to disable transcoding in the UPnP config screen.
Posted on: 17 February 2016 by Steve Smith
Thank you. However, sometimes tracks stream in FLAC, sometimes they don't. Bitrate varies, sometimes 128, sometimes 270. Yet I am sure that when I ripped them all with dbPoweramp, the setting was FLAC lossless.
How would I change that setting you referred to? I am as Manuel here: "I know nothing".
Posted on: 17 February 2016 by ChrisSU
I think the first thing you need to do is look in the folders of your music library and check what format the individual files are. If some are in a lossy format, the only solution is to re-rip CDs or re-download in a lossless format.
Posted on: 18 February 2016 by Steve Smith
Thanks. I'll look at the files in the folder.
