NDX Fault 35
Posted by: John Willmott on 18 February 2016
My NDX has just thrown:  Fault 35 DSPDAC Reg 4(W) Fail ..
I had just chosen my first track of the day to play ... the unit just stopped.
Looking back over the forum I see that a couple of you have reported this issue too .. a turn off with a 30 second concerned pause before turning it back on seems to have done the trick and we're back up and running.
Did anyone ever find out the cause ?  Thanks.
Posted on: 18 February 2016 by Mike-B
No,   but its never come back in the last 6 months
Posted on: 18 February 2016 by John Willmott
Thanks Mike .. the old "recompile and re-run it" solution never has never really sat very well with me though ..
Posted on: 18 February 2016 by Pcd
Had this once with my NDX switched it off for a few minutes after restarting the problem has never reappeared this happened about four  months ago ???
