I have added a new album to my iTunes and it does not display properly from the Naim ios app. From Artist/Album it displays the album title, but click through and no tracks shown - blank.
The tracks are there as when I choose 'All Songs' they're listed! Tried re-loading into iTunes, but problem remains. Is this a known problem? Is there a simple fix? It's flippin' frustrating! Wondering if the next time I add anything to my iTunes I'll see the same problem :-(
Posted on: 24 February 2016 by ChrisSU
Sometimes the app is a bit slow to see updates to your library. I've no idea why. Clearing the UPnP cache often helps (in Settings > Input Settings > UPnP Settings.) Then try restarting your computer and streamer. Can't promise this will work, but there's no harm in trying.
Posted on: 24 February 2016 by D-R
Chrissu, you are a star! The problem had been around for a few days, so it wasn't a time related problem.
However, clearing the cache sorted it - good fix! Thank you, much appreciated :-)
Glad to hear you're sorted. I've found that new additions and metadata changes sometimes update instantly, or they might take a couple of minutes, hours, days or even weeks to be seen by the app. Weird, but clearing the cache usually sorts it.
