You have no idea or do you?
Posted by: Sounsfaber on 25 February 2016
Well, had the serviced 135's plugged in for a couple of weeks now......
WOW
omg these are 28 years old omg omg omg.
my set up has just been open to the universe. I would say you have no idea but I guess you do.
i have them stacked on a naim fraim base which is the icing on the cake, they have open up a part of my life that I just can't describe.
From this experience..(I've gone around the mulberry bush only once)
i would start where I will finish. The first buy would be a naim fraim then powerlines then boxes.
regards Mr blown away
oh thank you Ricard for recommending the 135's
Posted on: 25 February 2016 by The Strat (Fender)
Up there with the Nat 01 as one of the iconic Naim products.  Result!!!
Posted on: 25 February 2016 by Christopher_M
Great headline.
You are quite right, I have no idea about the NAP135s. Enjoy them.
Chris
Posted on: 25 February 2016 by Singslinger
In 1994 I went from a 250 to 2 x 135s and experienced a similar epiphany.
I kept the 135s for 17 years - they drove everything I threw at them with ease and utter musicality.
Enjoy.
Posted on: 25 February 2016 by elkman70
What did you change the 135s for and are the new power amps better?
Nick
Posted on: 25 February 2016 by Sounsfaber
elkman70 posted:
Nick
Went from a lovely serviced nap 180.
At first I was a little worried as the 135's didn't come on till about the 7/8th day, then I introduced the fraim base omg omg omg....  Yes sooooooo much better,oh it's just the music!
Posted on: 25 February 2016 by joerand
Sounsfaber posted:
I think I get what you're saying here. I'd do the same if I had to start again. Racking, cabling, and room treatment would come before gear upgrades. Better to have lesser gear situated correctly than greater gear set for shit. Hopefully one day I'll get there.
Posted on: 26 February 2016 by Sounsfaber
joerand posted:
Sounsfaber posted:
Roger that. However I did get a seperate wire off my  house mains to a none switched hardwood/brass  (Heritage style) wall socket. Got the "really big earth wire hook up to an over size brass bus etc. That bit I got right from the get go.
