N-server App is repedely closing down
Posted by: kiba on 09 June 2011
Using an Ipad and n-server app to control my unitiserver. Are now experience shut down on my n-server app. Every time I starts the app, it will immedeally shut down again. I have tried to shut down my Unitiserver, then I Can start n-server, but after picking an album, the app starts to shut down again All over. I Can use the Naim desktop client on my PC, no problems there
Posted on: 10 June 2011 by Phil Harris
Hi Kiba,
I've made a sticky at the top of the forum with the information which should help you to give us the information we need to be able to track down your problem...
Phil
Posted on: 10 June 2011 by 0rangutan
Thanks Phil.
I find that n-Stream sometimes crashes on resuming from the background, but then always works fine once re-launched.
Where do you want us to send the crash reports? To you directly?
If you have elected to send crash reports to Apple then the reports will be sent to the developer directly otherwise you can send them to me...
Phil
Posted on: 10 June 2011 by kiba
This App is running on a IPAD, and I don't syncronice with ITunes or other. Please guide my to where on the IPAD these crash files are places. A's I'm only using the IPAD A's a big remote how Can I upload files to you (diretly to this forum - ? Or .)- I'm still use my MS PC for mails and other.
There is no file manager on the iPad itself so this cannot be done just from the iPad. Surely you must have synced the iPad with iTunes to start it up initially, do you not sync it at all?
Phil
I have just sync the IPad now to ensure that I'm using the latest firmware 4.3.3 next time the issues is there I Will do the sync, and look for the files as you specify, thx
Posted on: 12 June 2011 by kiba
I now have the situation, made a sync with the IPAD and my PC-Itunes, but there is no *.crash files uploaded to my C:\, infact there is no dir on my XP pc C:\Documents and Settings\<USERNAME>\Application Data\Apple Computer\Logs\CrashReporter\MobileDevice\<DEVICE_NAME>
Posted on: 12 June 2011 by DavidDever
Your router may be dropping the iPad connection when the discovery messages are initially sent from the app - try turning auto-discovery off (manually entering the IP address) and see if that works.
Will do, thx
