Nstream on Ipad?
Posted by: Tonkis Q on 14 June 2011
Is Nstream more stable on Ipad than Ipod?
Posted on: 14 June 2011 by Simon-in-Suffolk
Hi - for whats its worth I have not had a single problem running N-Stream on a first generation iPad.
Simon
Posted on: 14 June 2011 by Tog
It works very well on iPad 1 but even better on iPad 2.
Tog
Posted on: 14 June 2011 by Tonkis Q
I tested my friends sonos and iphone app this weekend, it seemed more stable and a lot faster.
Posted on: 15 June 2011 by KRM
I have used PS Audio's E lyric and it really like it. It does all the stuff we would like the Nstream to do, but if it's not on screen or the iPad is in sleep mode the music stops working at the end of the current track. Is it just me? Is there a way round it?
Keith
Keith
Posted on: 15 June 2011 by Guido Fawkes
Originally Posted by Tonkis Q:
Thanks I tested my friends sonos and iphone app this weekend, it seemed more stable and a lot faster.
+1 - the Sonus app/interface be superb - the SQ though be not as good as some ways of feeding music to a Naim DAC though, but it be possible to improve the Sonus.
Posted on: 15 June 2011 by Dustysox
Does the NDX not support "seek/ffd" within a track? Is this true for Naim CD players as well?
Posted on: 15 June 2011 by Simon-in-Suffolk
Hi, currently the nDX does not support seek, wish it did.. Perhaps it will come shortly, bit of a pain with very long tracks.
Naim CDPs do support seek.
Simon
Simon
Thank you Simon.
Strange one that.
Posted on: 19 June 2011 by Steven Shaw
Does using N Stream on an Ipad actually offer any more functionality than using an Iphone? Or is it just simply a case of bigger display.
Posted on: 19 June 2011 by Tog
I use both and to be honest the iPhone version is often more convenient but it does drain the battery. The iPad allows the app to work more intuitively through fewer menu choices and shows off cover art quite well. It is not yet as well thought out as say Apple 's remote but with a fast and efficient UPnP server it is almost as quick. On the iPad 2 it runs very well and I kind of like it.
Tog
Tog
