Distance to router
Posted by: kiba on 15 June 2011
Either is good, cat5e will happily transfer over 100m of cable, 15 is nothing.
That being said if you can keep the switch and router away from your hifi thats no bad thing as they are usualy resplendent with a crap wall wart
Search out CAT5e keystones on ebay and build yourself a nice little wall box for an ethernet point. the switch can be in the loft then or what ever.
Simon
My LAN is Cat6, is a Ferrit clamp still a recomandation ??
Simon
Simon
Would that also go for shielded cable types? (i.e. properly connected on both sides)
The RFI typically of concern here is the interference generated from LAN electronics. This carries along all the conductors including shield, hence the term common mode.
One drawback of shielded cable is that although a clamp on inductor will help inhibit the EMI carried on the shield, it won't inhibit the common mode EMI of the twisted pairs in the same way and so shielded cables might be harder to inhibit RFI overall, especially if the source is generating the RF current with respect to earth.
Also one common misconception is that grounding equipment with cable stops RFI. This is just not typically the case, and frequency/wavelength and distance to physical earth (not mains earth - which is there for safety not RF grounding..) start to have a impact on effectiveness. The best way to stop RF current is to balance it out so it cancels it self or make the RF currentbwork against an inductive (or capacitive) reactive load (like a resistor to DC).
Simon
Simon
Simon
So the RFI generated by the LAN equipment travels 'inside' of the outer-shield of an STP-cable and can therefore not be 'reached' by the RFI-inhibiting effects of the clamp (just to check if I understood correctly
So, can there be a general advice on cable choice?
Is a properly terminated STP-cable better or worse than an UTP-cable with an RFI-clamp? Does it depend much on RF-surroundings, say WiFi, DECT and microwave?
Continued .......
I read that not all Ferrite clamps are born equal
. Especially maximum impedance and 'optimum' frequency differs considerably. Some clamps more focused on power lines and other (high frequency) more focused on LAN and high speed data cables.
Would something like this be most appropriate for a Cat5e / Cat 6 cable?
But in our application here, we are using a blunt tool, and so most clamps will be fine
The best place for the clamp would be prior to the NDX, and additionally you can try right by the LAN switch or 'router' etc.
But remember add more until you hear no difference, and if it makes no difference at all take them off.
For critical industrial applications like in operating theatres special low EMI switchs are used but they are very expensive, and perhaps slightly over the top for our use, so cheap clamps on regular UTP cable (CAT 5) is what I use and recommend.
BTW my teory with wifi and apparent sound degradation is nothing to do with the wireless data network, but more likely due to the RF generated. I
Simon
