Naim Unitiserve UPnP Server settings
Posted by: antmast on 13 March 2016
The Naim Desktop Client has a tab under tools for the Naim UPnP Server settings. The Miscellaneous Category / Transcoding has an Auto and a Native setting, along with some others. Since my Unitiserve is going into my DAC and then my amp would which be the better setting,  Auto - which detects the controller type or Native - which hosts the file in its native format? Thanks.
Posted on: 13 March 2016 by Adam Zielinski
Native. Provided your DAC can handle then sampling frequency and the bit depth.
