Any stand recommendation(s) for Rega RS-1
Posted by: Michael Mccullough on 14 March 2016
Would like to put as close to wall as possible. Thanks.
Linn Kan 2 Stands may do the job if you can find a pair- can't get much closer to a rear wall , that's for sure. Not sure if the Rega's like a heavier stand? The Kan 2 is an open frame design which does not allow for fillers..Good luck!
ATB,
Mark
Being rear ported, they will need to be a reasonable distance from the wall, say a foot or so.
Rega make a wall bracket for the RS1, so they must think they are OK close to a wall. Of course that's not what one would expect from a rear ported speaker, but who knows...
The RS1 can go as close to the rear wall as possible and that's exactly where I had the best results , with them mounted on very heavy Partington Dreadnought Broadside stands.
Picture from the time ....
Folkman posted:The RS1 can go as close to the rear wall as possible and that's exactly where I had the best results , with them mounted on very heavy Partington Dreadnought Broadside stands.
Thanks for the Tip. Like those and have also been recommended the Atacama. Hard to find in the US though.
