nap 300 Dr problem
Posted by: imaginator on 18 March 2016
Hi All
I've just received a new nap 300 Dr for a week demo to match with my Nac 282 + Hi_CAP DR to replace my Nap 250-2.
I connected the cables according to specifications on manual but no sound appears. I checked again and again the connection but nothing happens.
I can hear a very weak sound just if I turn the knob of volume to max and I put my ear very near of the loudspeaker.
If you connect the nap 300 to a no naim pre with a balanced cable it works. So i presume the problem is in other place..
If I connect the nap 250 all it's work...
Can anybody help me?
Thank you
Posted on: 18 March 2016 by hungryhalibut
I expect you have connected the din to xlr leads the wrong way round.
Posted on: 18 March 2016 by Southweststokie
Hungryhalibut posted:
+1
Posted on: 18 March 2016 by imaginator
Thank you
I think i've used this configuration:
Have another look.
Posted on: 18 March 2016 by Cbr600
I had a similar problem with 500, and found that the burndy leads were connected wrong, as they are specifically handed for left and right connection
The Nap 300 has gone to my dealer for a check. Tomorrow I will take it  back and  have another look. But..Sorry.. I am not sure what I must pay attention: The right output DIN (4 pins) of HICAP to right channel XRL  and left XRL to left DIN (4 pins)?
Do you mean if I invert the Din plugs of the leads one to each other it doesn't work?
Posted on: 18 March 2016 by james n
Keep the din connections as they are on the hi-cap and swap the connections (XLR end) at the 300. Swap red to green and green to red on your diagram.
Cbr600 posted:
Really ? - i didn't think the Burndy cables were handed. They have a directional marker on them but both cables are the same. They were on my 300.
Cbr600 posted:
I put the marks of the burndy lead- in the amplifier direction. I think this is right...
Posted on: 18 March 2016 by Richard Dane
Check the DIN-XLR cables. Make sure you have CH1 (left) with the green band and CH2 (right) with the red band.
OK, I hope everything works
Thanks to All
I can not wait to try the new 300 DR!
Posted on: 19 March 2016 by rsch
imaginator posted:
Thanks to All
Hi,
Just for curiosity, where are you located?
Have you ever tried a better pre than 282 ?
Roberto
Posted on: 19 March 2016 by imaginator
Hello guys
everything works fine now .
I'm really happy
The music flows easier than before and  all the sound parameters are better now.
My loudspeakers Totem Forest are not  difficult to drive, but now they are flying !
Thank you for your precious help.
rsch posted:
imaginator posted:
Thanks to All
Hi,
Roberto
Hi Roberto
I'm Italian and i had a 552 demo few years ago.
Fantastic.. but too expensive for me.
imaginator posted:
rsch posted:
imaginator posted:
Thanks to All
Hi,
Roberto
Hi Roberto
Hi Imaginator,
I'm Italian too, i asked about the preamp since now with 300DR a 252 would be a better match in theory.
Roberto
Posted on: 19 March 2016 by Michael
I think many owners get confused with the red to right and green to left instruction as this refers to looking at the back panel of the amp, so as you look at it from the front the red banded lead is going to the left hand side and the green one to the right.
rsch posted:
imaginator posted:
rsch posted:
imaginator posted:
Thanks to All
Hi,
Roberto
Hi Roberto
Hi Imaginator,
Roberto
Hi roberto
It could be .! But I'm very happy with my Nac282 plus Hi-cap DR , maybe in the future...nac 552 used  ;-)
Michael posted:
Yes, it created confusion for me.
