Supernait 2 changing audio channels
Posted by: Nic Chan on 21 March 2016
I have a problem for my supernait 2 reciving infrared beams from the remote since it's blocked by the edge of my bed in my bedroom. I try to connect the NDX remote out to the supernait 2's remote in with a 2 sided 3.5mm jack and turned on preamp from the system automation so I can control the volume with my iPad.
But now I encounter a problem when I try to change songs on Naim app my supernait 2 channel will bounce from CD (where I connect the NDX from) to aux1. Is this a know problem? Any fix to this? It's kind of annoying...
Thanks for the help
