Update metadata
Posted by: robgr on 26 March 2016
I am uisng a NAC-N 272 and am streaming via MinimServer on a QNAP NAS
What is the best utility that would assist with updating metadata, missing artwork etc?
Posted on: 26 March 2016 by robgr
I have been looking at MediaMonkey but it is showing read only when looking at Media Servers\MinimServer folders
I noticed that the NAS folders are read only so I changed them via Windows folder properties, recheced and there back to read only
What am I missing, what is the best way to approach this, how might I change the pernissions for the NAS folders?
Posted on: 26 March 2016 by hungryhalibut
I use dbpoweramp, which works really well and is easy to use.
Posted on: 26 March 2016 by Maxwell
Hi, I use Metadatics, which works well, though I have tried anything else. I too use a QNAP.
Posted on: 27 March 2016 by robgr
Thank you both, I do use dbpoweramp but I don't believe this can auto-tag (which is what I really want)
I am WIndows based so Metadatics is not an option, I don't know if it supports auto-taggiong though
MediaMonkeydoes have auto-tagging features but I can't currently get around the read-only issue
I must be missing something on permissions related, I suspect on the NAS
I can change the permissions via Windows but it just doesn't stick, most odd!
Posted on: 27 March 2016 by dayjay
Tagscanner does it on PC does it brilliantly, it's free too.  Can't recommend it enough and he updates it regularly - well worth a donation if you do use it
Posted on: 27 March 2016 by Reinibert
Have a look on mp3tag. It has all you need.
Posted on: 27 March 2016 by Harry
dBpoweramp. Robust, reliable and easy to use. It will do other things besides. And it does them well.
Posted on: 27 March 2016 by Simon-in-Suffolk
+1 for dbpoweramp and it runs on both Windows and OSX
Posted on: 28 March 2016 by robgr
Thank you all for your recommendations
Posted on: 28 March 2016 by Bart
I highly highly recommend editing metadata BEFORE moving files to the server. It's much easier to get it right on the server by having the server index the properly-tagged files than by editing the tags and hoping the server picks up the changes.  Some servers are better at this than others, but in all respects I think that the best practice is to do the edits outside of the server environment if possible.
