DVD 5
Posted by: Harwell on 27 March 2016
DVD 5, will not play DVD's. Any ideas why, anyone? RGB displaying. AUTO displaying. 'STOP' stays lite up. Sounds like it trying to read/play then goes back to 'STOP'.
Connected to Nait 3. Playing music beautifully, TV booming through speakers.
Much appreciated
Posted on: 27 March 2016 by Richard Dane
Has it just started to happen? habe you changed anything?
Do you get the dvd5 setup menu? I.e are you getting a picture signal from the player?
What region is it set to and are the discs  from that region?
Posted on: 28 March 2016 by Harwell
Hi Richard,
Not watched a DVD since I was gifted it a week or so ago. Don't think I've changed anything. I followed the set up instructions from the manual.
Display screen shows CD times, 'OSD', 'AUTO' 'PAL' etc Also done 'RESET' a few times. Restarted player. No Joy. Tried different cables, including red, blue n green and SCRAT
No signal is being received and DVD is not reading/playing at all.
Region 2 which played on previous Sony DVD player
As I say music plays beautifully.
Posted on: 28 March 2016 by Dungassin
I was going to post a comment, but re-read your original post, and it was not necessary.  How do I CANCEL a post before posting it when I decide not to post after all?
Posted on: 28 March 2016 by hungryhalibut
You just swipe it off the screen to the right.
Sorry, don't know Dungassin.
Posted on: 29 March 2016 by Super
I guess it's showing it' age now. Mine has 3 or 4 attempts to eject open from switch on and then sometimes it's struggles to play some DVD's, so far it does get there.... eventually !
Posted on: 29 March 2016 by Harwell
Could be the age. I'm told it was a demo model. Looking at it, you wouldn't know. Even the instruction manual is prestine, so its been well cared for I would say.
Just a shame, I was looking, still look forward to experiencing the much talked about visual quality
We'll just plough on and see we get to.
Posted on: 29 March 2016 by Richard Dane
It sounds as though it may well need a replacement laser mechanism.  I'm not sure what the availability is on these - I think Arcam and Meridian used the same one for a time.
Thanks. Will look into it
I do have a Meridian CD 506 player which jumps occasionally when playing. Nice piece of kit
Check with Naim first on whether they can replace the mechanism. I don't know what their spare stock is like - maybe exhausted after so many years.  However, you may be able to source one independently - I think there were at least two different versions used of the DVS mechanism - pre and post ROHS - so you need to know which one you have.  It was also a mechanism used by Linn as well as Arcam and others.
Posted on: 29 March 2016 by Dungassin
Hungryhalibut posted:
I assume that's for iPad, iPhone etc.  Don't know HOW to swipe it off screen to the right on my iMac.
