Powering down system
Posted by: Got Hi-Fi? on 31 March 2016
Do you power down your power amp when not using it? or do you leave it on all the time as well as your pre? I am not really talking about for long periods, but say, during the days when you are at work, if you listen during the evenings.
Posted on: 31 March 2016 by hungryhalibut
I don't, most don't, some do.
Posted on: 31 March 2016 by Harty601
Lots of threads about this. In my opinion leave powered up - sounds better and less chance of fuses going pop when powering up and down. I also believe (from previous experience) that power supplies have longer lives when not turned on and off on a daily basis.
Posted on: 31 March 2016 by joerand
There is a search icon in the black menu bar on the top of this page. It looks something like a hybrid of a magnifying glass and the letter Q
Open that window and click on "Advanced Search". Your query is one of the most frequently asked questions here so you should find lots and lots of results.
Posted on: 31 March 2016 by Peter Dinh
I always leave everything on, unless when I go away on a long trip or during some bad, stormy days.
Posted on: 31 March 2016 by Got Hi-Fi?
Thanks for the replies. I will continue to leave it on.
Posted on: 31 March 2016 by rjstaines
Got Hi-Fi? posted:
Good choice !
Expensive choice, but then what else would you be spending your hard-earned on if not powering your audio equipment ?   Powering your yaght?  Powering your light aircraft ?   Financing an expensive set of wheels ?  ...no, for me I've given up the yaght, sacked the crew, sold the wings, scrapped the wheels and now sit in comfort and bliss in front of my always-on Naim components.   Does my green conscience bother me ?   ..of course, but this one of life's struggles we have to endure in pursuit of audio nirvana
Posted on: 01 April 2016 by joerand
I've managed to keep my yacht, fired the chef, and am now relegated to do my own cooking. Financial hardships arise, but at least I can afford to keep my gear fired up most all the time.
Posted on: 02 April 2016 by GregU
How much a month does this cost?
i leave the pre and power on
Posted on: 02 April 2016 by Rjt36
Another question I'm a bit embarrassed to ask!.........but should I switch my 272 off at the back of the unit when I've finished listening or is there a way to simply put it into standby? I couldn't find anything in the manual. Thank you.
Posted on: 02 April 2016 by benjy
I don't own a 272,but traditionally (and that is why so many have asked) naim "prefers" if you leave your equipment powered up at all times - that is why the only power switch is not readily accessible, but at the rear. I assume the 272 is a naim and not some other company
thank you.
Yes it is a Naim - Nac-n 272 - but the reason for asking is that I can't see anyway to even put it into standby, so to close down I radio or Tidal, the only way I can see is to turn it off at the rear? But I must be missing something?!
Posted on: 02 April 2016 by Dungassin
Well, I don't own one, but I've just looked at the manual online.  Pressing STOP on the N272 stops playback (including radio), so I assume stop on the remote would do the same thing.  If that doesn't work, I suggest MUTE.  Power consumption of the unit is low.  Just leave it switched on.  Hopefully someone who actually owns one with give a better answer.
Posted on: 07 April 2016 by rjstaines
I have a 272 and as Dungassin says above, pressing STOP seems to do just that.
Handy little button really
