Choices and Rack Height
Posted by: Mort2k on 06 April 2016
Dear Forum.... its been a while , hope you are all good ![]()
Two quick questions.
Current Space only allows for 1 stack, current rack holds 5 boxes (base+5 shelves), top shelf not free for equipment in compromise with the boss
So is Base + 6 shelves to high ? Anyone got pictures of Fraim at this height ?
If 6 is good then next move is easy - add PSU to streamer !
Current systems - ND5/52/SC/135/SBL
If 6 is pushing it we get to the second question, would you go to:
- ND5/XPS/52/SC/250-2 - same box count swaps 250-2 for 135's (dont know how the older 135's compare to new 250-2)
- NDX/52/SC/135 - same box count - is the NDX worth the upgrade from the ND5 ? (NDS is an option but down the line a god few years)
- Or go upgrade to cables, currently Highline and NACA5
- Current rack is not FRAIM so could make this investment in FRAIM and keep equipment the same.
Thoughts as always appreciated. Other options considered as well ![]()
Rob
