Power Up/Down Sequence
Posted by: Graeme H on 07 April 2016
Of coure I normally leave everything powered up, but there are occasional times I have to turn things off and I'm unsure on the correct sequence following a change in my set-up.
It used to be very simple: The 200/202 amp combination and a CD5x with a Hi-Cap on the CD5x. Powering up I used to switch on the CD player and the Hi-Cap first (never sure if it made a difference which way round) then the Amp. Powering down in reverse: amp then CD player.
Since then an NDX has been added and the Hi-Cap moved to the amp. I've tried following the same sequence, ie CD and NDX first on powering up, then Hi-Cap and amp - sequence reversed when powering down - but now I get a horrible spike which sounds terrible through the speakers (of course I have the volume turned all the way down).
What sequence would other posters use for powering up and down?
