Unity Serve
Posted by: Blue Flame on 29 April 2016
I have a NAS that I want to use as a backup for my Unity Serve.
I have followed the instructions but I have not managed to get the Unity Serve to "see" the NAS so I can not use it as a Backup disc.
My NAC-N 272 can "see" the NAS and play music from it.
It is a LaCie NAS and mycumputer is a MAC running El Capitan.
Posted on: 29 April 2016 by dsc
Hi Blue Flame,
You might find the information in the following thread helpful.
https://forums.naimaudio.com/to...ly=51267011725071066
Good luck,
Posted on: 29 April 2016 by Bart
OP, something is wrong in your setup.  One can do this, but there is not much room for error.
Posted on: 29 April 2016 by Mike Woodcock
BlueFlame - First of all, is the NAS visible in Finder on you Mac? - If No, this is a network issue, rather than a US/Naim issue.
If yes, I assume that when you go into maintenance on n-serve on your Mac app, you can't see it in "Network Shares" in "Maintenance"?
I would suggest creating a new, blank share on your NAS that will be dedicated for your backups and nothing else.  Reboot the NAS, close down n-serve and then go back into n-serve once the new share is visible in Finder and Re-Scan network drives...
Posted on: 30 April 2016 by Adam Zielinski
I encourage you to dig up those pdfs Naim has created for setting up US with various NAS's.
If you use QNAP I can help out with the doc in question and your set up. Email is in my profile.
