FlatCap XS or Olive/CB HiCap to power Nac 202
Posted by: Bob the Builder on 29 April 2016
I am in the process of upgrading my preamp from 122x to a 202,  I will buy a used Napsc but my question is until I can afford a HiCap DR should I use my FlatCap XS or sell it and buy a used Older kit HiCap?
Posted on: 29 April 2016 by Simon-in-Suffolk
My view is the HiCapDR significantly transforms the 202.. and here it was the DR that made the big difference, especially with the NAPSC connected.
Posted on: 29 April 2016 by Marksnaim
I agree with Simon. I'd keep the FCXS in place until you can afford the HCDR. Half way measures always ending costing more in the long run. I know I've made that mistake a few times. But then I'm impatient.
