Naim NDX outputs
Posted by: Beachcomber on 11 May 2016
A quick question - I have just bought an NDX (and so far very pleased with it), and see that you have to select the output, between DIN, phono and digital.  Is it not possible to have both DIN and spdif outputs simultaneously?
Steve
Posted on: 11 May 2016 by Paradox2701
Dear Steve,
you can. Just enable both analogue and digital outputs on the NDX setup and enable the appropriate outputs.  I enable both DIN and SPDIF when I want to compare my external DAC with the DAC in the NDX.
Posted on: 11 May 2016 by Beachcomber
Fantastic - many thanks for that.  I will have a play.
Steve
