Chromcast & Uniti
Posted by: Ptangyang on 14 May 2016
Hi all
Am after a little bit of noob advice. Is it possible to stream audio from my laptop/mobile device to my Uniti using Chromecast? The Chromecast connection is HDMI so I guess I'm asking is there a way of connecting HDMI to any of the inputs on the Uniti.
Thanks, any help appreciated.
Posted on: 14 May 2016 by gert
I think you need an hdmi to spdif converter that is extracting the audio signal from the hdmi protocol. Or you take the chromecast audio that offers spdif out.
Posted on: 14 May 2016 by hungryhalibut
Yes, you can do this. Just use an optical lead.
Posted on: 14 May 2016 by trickydickie
Hungryhalibut posted:
I believe only the Chromecast Audio has optical out, the 'normal' one designed for TV only has HDMI.
Posted on: 15 May 2016 by hungryhalibut
Ah, I see. I used the audio version with an optical lead. It sounded awful, so I sold it.
Posted on: 30 May 2016 by Ptangyang
Thanks all. Word of warning, frustratingly you can't stream from iTunes, which was the whole point. Back to the drawing board!
Posted on: 30 May 2016 by ChrisSU
Ptangyang posted:
You need to run UPnP server software on your computer to play music stored on it on a Naim streamer. This will be able to see your iTunes library or other stored music, and serve it over your (preferably wired) network to the Uniti.
