Is my HDX internet connected or not?
Posted by: oscarskeeper on 23 June 2011
Hi all, hoping for a bit of help here.
My HDX (2x400gb)Is showing Internet connected as being false on its system status panel. However, when I tried to rip new CDs, it says it is doing an AMG look up and recovers the track data. It is doing this with CDs which are newer than the machine, so I assume the information can't be coming from its own database.
It is connected to an airport express, I believe the newest model, which acts as a bridge to the Time machine capsule used as a route. It all initially worked fine and set itself up without any difficulty. However, after one day we had a power cut, upon restarting everything, I noticed that the system status had changed.
Is anyone able to help as to what is happening on whether this is likely to cause a problem. I'm specifically thinking of when the Internet radio update becomes available, as I'm very keen to have this work.
Many thanks
Ben
