Will nVi work with DVI to VGA cable?
Posted by: GreenAlex on 30 June 2011
Hi,
I want to borrow a monitor from a friend but it only has a VGA input.
The n-Vi is only PAL/NTSC, so resolution isn't an issue, but will the nVi output an analogue signal via DVI which will be properly converted to VGA?
Anybody ever tried this? Do you see a difference on a 20" screen between nVi DVI-HDMI and DVI-VGA?
Thank you :-)
Posted on: 01 July 2011 by DavidDever
DVI support is DVI-D only–to use a VGA input (as opposed to component video, which would be preferable), one requires a component-to-VGA converter (of which poorer-quality samples will drastically affect performance).
Posted on: 01 July 2011 by GreenAlex
Thank you David :-)
Then I guess I will have to borrow a different one.
