Unitiserve - General problems/issues
Posted by: AKD on 01 July 2011
My unitiserve is skippin/jumping within tracks - both on Local Drive & NAS drive. Also, it won't play CD direct or Rip CD.
I've re-boot, reload service pack 2 etc without solution. I am taking it to the dealer/naim.
The player is about 7 months old and has worked flawlessly until now.
Anyone with similar problems or am I alone?
Posted on: 01 July 2011 by garyi
Sounds like an harddrive is going nova.
This is not restricted to naim, when they go wrong the oddest things happen.
Posted on: 04 July 2011 by AKD
This is an update on my unitiserve reported problems...
The problem has resolved itself, How? I dont know.
I got home on Friday evening and decide to play it again before packing it up - to take to dealer on Saturday.
The playback was Ok - no skipping/jumping, then I slotted CD into the drive - it interuppted the HD playback and played the CD in the drive. Later on, start HD playback & I change it to ripping mode & slotted another CD & it ripped OK during playback.
It performed perfectly throughout the weekend. Therefore if you ever have simlar problem, reboot, reload the service pack 2 and leave it on for the next 12 hours before playback.
Also, I had to rescan the drive for downloaded (NOT Ripped) music (from B&W site) before I could replay any of the music on the drive.
PS: the support from my dealer (Acoustica) & Naim support department is first class - prompt, instant & decisive.
Posted on: 06 July 2011 by Stover
I had A UServe on loan for some weeks and it acted similar to yours. After a restart I was also fooled to believe that problem was solved, but again after some days it started jumping again.
I asked Naim about this and I was told it needed to go home to Salisbury.
Regards S
Posted on: 06 July 2011 by AKD
thanks for the update...
so far so good, 5 days & counting.
It will be nice to know, if its hardware or software issue.
Posted on: 18 July 2011 by AKD
Stover, you are right!
The problem is back but this time round, it's pausing for 4 to 10 seconds (more frequently) instead of skipping.
Also, it froze & I had to reboot US.
Anyway, I've taken it to my dealer to be sent to Salisbury.
Posted on: 18 July 2011 by KRM
The power supply on mine died on Friday. Luckily my dealer has demo version and has let me borrow its PS until Naim can send a new one.
Not sure what went wrong, but when I switched back on it had reset its date to Jan 2009, which temporarily stopped new CDs from showing in the New CD list. I was able to fix it then discovered that some CDS can't be deleted, they disappear but reappear later (using the Desktop Client). Bizare!
Keith
Posted on: 18 July 2011 by mudwolf
doesn't bode well for teh technophobe like me.  I'll wait another year for them to figure out all the digital stuff.
This means I can get someone to do a nice paint job on my apartment instead of me doing it all.
Posted on: 18 July 2011 by DavidDever
Keith
Sounds like your unit got zapped.
Posted on: 19 July 2011 by KRM
Hi David,
By "zapped", do you men a surge or mains spike? In Naim's defence, the bit that failed was the only part thar they don't make!
Keith
Posted on: 22 July 2011 by AlexWard
Just got my UQ back from Naim service. Mine kept eating discs - and there was no way to eject them.
Turns out the optical drive completely failed. Naim requested to keep the troublesome CD that caused the final lock up. (It was the 'Imagine" soundtrack CD)
Got it back with a new fascia plate - with the pinhole eject on it.
Posted on: 25 August 2011 by AKD
A closure on this problem...
Sent my US to Salsbury - checked & replace the face plate.
Got it back & so far so good for a month now...
Thanks to the contributors.
Akd
Posted on: 22 October 2011 by AKD
The US saga continues,
Got it back from Naim - diagnosis of nothing wrong with it.
Since then it skips occasionally, I've added net gear switch to minimise bt router drop out, moved the music from US local hard drive to Seagate go flex NAS.
Now, music is skipping sporadically, I could listen for hours without skipping & somedays it can skips on every tracks of an album.
Last week, it froze with the error message "verifying DMI Pool Data...... DISK BOOT FAILURE, INSERT SYSTEM DISK"
I had to reboot with power switch off & on to resume playback.
I had a squeeze box duet for 3 years without a glitch. What is Naim doing wrong?
Naim ask me send it back - I am reluctant to do so, because I don't think Naim is being honest with the bugs in their machine / software.
Posted on: 23 October 2011 by Mr Underhill
AKD,
It IS a pain but I would go with them.
I have used a US, and have been running with an NS01 for the best part of a year with none of the issues you are experiencing ......although, I bought the NS01 as ex-dem. In fact it was brand new, but supplied as a replacement for one that had been playing up, the original customer decided to take a different route.
I was a early buyer of the DVD5, which had an interesting early history! It ended up going back to base a number of times, but my dealer / Naim ensured all was put right.
Hope it is sorted to your satisfaction.
M
Posted on: 23 October 2011 by AKD
Thanks Mr Underhill,
I just want Naim to be honest, i think the problem started with firmware 1.5a update. Surely, US should run without problems considering the experience gained with HDX & NS0 series.
I love the product so much that, I sold my existing system for all naim system Nac202/Napsc/Nap200/ndac.
I was convinced it was my router but am not so sure.
Akd
Posted on: 23 October 2011 by Tog
The uServe is IMHO opinion a hugely expensive white elephant that attempts to reinvent a wheel that is easily available elsewhere. Tog
Posted on: 23 October 2011 by Sloop John B
Come on Tog, tell us what you really think
SJB
Sorry guys - just put one of my beloved cats into the Cattery so my last post may have been a little lacking in subtly .... my bad my youngest would say. Togbad the Irritable.
Posted on: 23 October 2011 by Guido Fawkes
Have to agree with Tog on this ....
Get a Vortexbox - it simply doesn't have these problems and I can't for the life of me see what a US does that it doesn't for a lot less of the hard earned. I'm still lost as to why Naim makes it's own ripping solution; when it works as I'm sure it does in the majority of case then it is fine, but it can't rip any better than perfect or serve UPnP any better. To me the US just looks like a computer and I read hereon that its S/PDIF out is not on par with my UQ.
I read about discs getting stuck or skipping or doing something else that they shouldn't really do - none of Macintoshes or PCs I've used have ever done this and my Vortexbox doesn't, my Yamaha CD/HD recorder has never done it (sounds mediocre, but doesn't eat discs), even my Amiga has never eaten a disc - so I'm puzzled what makes the US so error prone.  Most un-Naim like.
I honestly don't think it is one of Naim's better products. A high quality CD Transport that could also rip to HD or NAS with top notch S/PDIF output is what I would expect for the US price, but unless I'm very much mistaken it is not quite that.
Posted on: 23 October 2011 by GerryMcg
This morning I was helping my son with his GCSE revision, the subject being statistics. One area of review was with regard to biased sampling and the inaccurate conclusions drawn as  a result. There are reports of some issues with the US  but of course people without issues will not post to that effect Likewise you appear to be comparing this fully biased sample with just your own experience of alternatives. I have had a CD stick in a car's CD player but have never had an issue with the Serve.
Without the Unitiserve I doubt that I would ever have got round to transferring my CD collection. It enables me to enjoy a listening experience (with nDac/555Ps) that far surpasses that which I obtained from my old CDS3. I am not saying there are not alternatives but I need a Naim box to fit alongside my other boxes.
The internet radio facility is good, and the n-serve is brilliant. It certainly gives good value for money for me, if not for others.
In response to GerryMcg
I agree with u & had brilliant 5 months & still love US. I just want advice or opinion to make it better. I still prefer server option (& HDX is too expensive for me) to streamer.
Do you use bt hub router or switch? Also, is your US -SSD or -HD.
Akd.
AKD,
This is a bit of an old saw now. Both 'sides' have good points.
Like Gerry, and I believe you, I think the brilliance of the Naim server solution is:
1. Easy good quality rips;
2. Great rendering of the remote files;
3. Expandability of remote shares;
4. Multiple serving of streams around the home; and now
5. iRadio.
None of which takes away from Vortexbox, Music Player, CMP et al.
Personally I played with the open source solutions, and built a PC that delivered great SQ. But ultimately I felt, and heard that the quality of the Naim server solution gave me all that I wanted.
The proof for me is the accelerating rate of my music purchasing!
M
Tog,
Looking at VB as a ripping solution for my movie collection.
M
It certainly works well - tagging is still a bit hit and miss but improving all the time. I'm still a huge fan of handbrake and prefer this as a ripper. Tog
Yes I agree my sample size was flawed and I should know better than to draw conclusions from it, I did say "when it works, as I'm sure it does in the majority of cases, then it is fine".
I'm glad a lot of folk who have HDXs an USs do not have problems and are very happy with them. Apologies for my earlier rant.
All the best, Guy
PS Gerry did you have Honda by any chance; I got a copy of Spirit's 12 Dreams of Dr Sardonicus stuck in my old one's CD player - don't have the Honda any more, but I did get another copy of 12 Dreams of Dr Sardonicus.
....... I'm still a huge fan of handbrake and prefer this as a ripper. Tog
I agree, great bit of kit.
Earlier this year I was crossing the border back from the Ukraine into Hungary and missed the train connection. Fortunately I had used HB to rip a load of DVDs to mp4, which were loaded onto an ASUS Eeee. Spent a couple of hours watching The Rock with a friend who had never seen it.
M
