Newbie help please.
Posted by: Siy on 04 July 2011
Hi. I have a naimnet server which feeds the house normally controlled by digilinx wall panel or ilinx app. I recently found n serve which allows me to control the analogue output, but does not give me control over the 6 zone outputs that I normally use to feed the whole house. I get all my albums etc displaying, just can't control the zone outputs.
Is there a naim app that will give me hhis control?
Thanks all
Posted on: 04 July 2011 by pcstockton
Try PlugPlayer maybe?
Posted on: 06 July 2011 by connon price
NServe controls only the local output on HDX/NS units and UnitiServe. The Digilinx app should be working for you for the distributed zones.
plug player, a UPnP controller, won't work to control your room amps which are Naim or Naimnet Digilinx.
Posted on: 06 July 2011 by Siy
Thanks all... that makes sense. Do you think that in time one of these naim apps may control the zone outputs? The naim apps seem much better and quicker than ilinx, plus look much better for scrolling through albums etc...
I am sure I saw a  post somewhere from Cedia that there is a new app in the making, and the screen shot seemed to show that you could use the different zones?
