Nordost speaker cable
Posted by: Nickalexander0703 on 05 July 2011
Hi I was thinking of selling my logitech duet / upgraded dacmagic / nait 5i and replacing it all with a qute. My only hesitation is the lower power output and whether or not I'll still be able to use my nordost speaker cable (gold flatline with nordost bananas).
At the moment I'm using neat motive 3 speakers and assume they'll be ok too? Cheers for any advice - nick
Posted on: 05 July 2011 by realhifi
You could use them but not sure why you would.  You could sell those and get yourself a set of NAC A5
cables made for the Qute and off you go.  I also sell Nordost; trust me, you want the Naim.
PS. Good move by the way.  The Qute is a superb all in one solution that you will NOT be sorry you purchased.  If the power proves to be not quite enough then just set your sights on a power amp down the road and you will be sitting in clover!
